säkrings nr?
paybull
jag undrar vilket nr det är på säkringen till brommsljuset? e30 325 -87a
tack på förhand....
häry
320is -88 s14b20
vet ej om det stämmer men jag hittade den förut när jag sökte på säkringar
Fuse Rating (amps) Description
1 7.5 Headlight, left high beam
2 7.5 Headlight, right high beam
3 15 Aux. cooling fan, low speed
4 15 Turn signals / emergency flasher / Active Check control / Digital Clock
5 30 Windshield wiper and washer
6 7.5 Stop lights / Cruise control / Active check control / ABS / Interior Lights
7 15 Horns
8 30 Rear Defogger
9 15 fuel delivery / Idle speed
10 7.5 Seat belt warning system / Service interval indicator / Tachometer / fuel economy gauge / Instrument gauges and indicators / Brake warning system / Back-up lights / OBC / Starter / Fuel delivery / Idle speed / Active check control / Stop lights and cruise control
11 15 1984-1987
7.5 1988-1990
Fuel pump
12 7.5 Radio power / Speedometer / instrument indicators / OBC / Multifunction Clock
13 7.5 Left Low Beam
14 7.5 Right Low Beam
15 Not in Use
16 15 Heated Seats
17 30 Sunroof / Power Windows
18 30 Aux. cooling fan, high speed
19 7.5 Aux. cooling fan / Interior lights / Power mirrors
20 30 Heater / Air conditioner / Auxiliary Radiator cooling fan
21 7.5 Glovebox lights / Flashlight / Ignition Key / Seat Belt warning / Interior Lights / Radio Memory / Trunk Lights / Active Check Control / Service Interval Indicator / OBC / Fuel delivery / Tachometer / Fuel Economy Gauge / Digital Clock / Multi Function Clock
22 7.5 Active Check Control / Front Parking Lights / Taillights / Front Side Marker Lights
23 7.5 Instrument Panel Lights / Front Parking Lights / Taillights / Rear Side Marker / License Plate Lights / Active Check Control / Rear Defogger / Multi Function Clocks / OBC
24 15 Turn Signals / Emergency flasher
25 Not in Use
26 Not in Use
27 30 Interior Lights / Central Locking / OBC / Radio Amplifier
28 30 Lighter / Power Antenna
29 7.5 Left Fog Light
30 7.5 Right Fog Light
inte bara bmw är bakjulsdrivet
Hälge
Säkrings nr: 10. (styrka 7,5A)
paybull
tackar!
sp
35
speed_
325i -93
530 -02
Vart hittar man sånt tabell till e36?
tack
Pengar gör ingen lycklig men jag gråter hellre i en BMW än på bussen
