Vad är det för fel på mitt Xenon?
Har problem med att höger halvljus slocknar. Jag kan då vrida av ljuset och sätta igång det igen så funkar lampan. Någon som varit ute för samma fel? Är det lampan? Styrenheten?
Mr
5
Mr88
-96 750ial
Tja,låter som det är styrdonet som gett upp,
testa att byta sida med lamporna.
har själv detta prob och i mitt fall så är det nya styrdon som behövs
letar just nu efter 2st begagnade till min E38..
Mr88
Har sett att det finns ett servicemeddelande om detta i BMW's TIS:
VS-22/Bahl Baugruppe/Group: 6363 01 01 (688) weltweit all countries
Datum/Date: 05/2001
Xenon light intermittently inoperable E46 with xenon light (option 522)
Complaint: The xenon light intermittently fails on either the left or right-hand side.
Cause: The wiring harness contacts the headlight's soft plastic cover and might press against the high-voltage connector on the ignition unit. In such cases, contact problems may arise due to the relative movement of parts.
Affected vehicles:
Manufacturing period: from start of series production until March 2001
Procedure:
1. Remove the bulb of the xenon light in the affected headlight.
Please refer to Repair Instructions "Replacing left-hand xenon light bulb" or "Replacing right-hand xenon light bulb", RA 63 99 076 / RA 63 99 077.
2. Check whether there are any signs of scorching either on the base of the xenon bulb or on its high-voltage connector.
If there are no signs of scorching on either the base of the xenon bulb or its highvoltage connector, continue with point 4.
If there are signs of scorching on either the base of the xenon bulb or its highvoltage connector, continue with point 3.
3. Replace both the xenon light and the ignition unit (the high-voltage connector is part of the ignition unit).
Please refer to Repair Instructions "Replacing left-hand xenon headlight ignition unit" or "Replacing right-hand xenon headlight ignition unit",
RA 63 12 870 / RA 63 12 871.
4. Secure the wiring harnesses (bundled earth straps) behind the soft plastic covers of the left and right-hand headlights so that they do not touch them.
Parts:
Description Part number Quantity
Xenon light bulb 63 12 8 361 007 1
Xenon light ignition unit 63 12 6 904 548 1
Cable tie 61 13 1 377 134 2
/ Micke
ki
226
kim750
530da-04
mixmaster_atv: jag verkar ha samma problem som Palte.
Du har inte lust att översätta till svenska ?
Kim
Har ju inte Xenon själv så jag kan inte säga exakt men jag tror det har något att göra med att kablaget till lamporna kommer ikläm och nöter på antingen lampans sockel eller styrenheten till ljusen (högspänningsenheten), detta ger väl förmodligen upphov till något överslag p.g.a. den höga spänningen!?
/ Micke
Ba
398
Bavaria1
iX3 Neue Klasse, -26, Fire red
Palte: Hade samma problerm som du beskriver, körde så i några år tills jag bytte lampan, efter detta var problemet borta.
Du kan testa med att skifta lampor, flyttar sig problemet är det lampan, annars styrdonet.
Lennart Bornhall
BMWCS #1085
Ska testa byta plats på lamporna, ska bara fixa någonstanns att slänga kåpan till min King Cab, det är ju så jäka kallt att meka utomhus.
Ba
398
Bavaria1
Ja det är ju inte alla som har dubbelgarage + carport till sina bayerska juveler....
Lennart Bornhall
BMWCS #1085
Inte än..... har precis köpt hus, bara en bilsgarage och carport.
Ps
72
Psz
530iA -05
Kolla mässingsblecken i lampkontakten innan du byter styrdon. Mitt ena ljus uppförde sig på samma sätt, kollade i kontakten och såg att det var svart på blecken. Lite puts med smärgelduk och lyset fungerade och gör det fortfarande.
MVH
Pelle
Pe
179
Petter1
330iM-03
Hade exakt samma fel.Bytte tändmodulen(styrdonet),sen funkade det...
