Oldtimer
753
Vin nr på 2002tii touring
tr
3.660
trucker
CS 3381
R75/7
325IT-06
330XI M-Sport
325 e30 -93
530DX-12 M-Sport
2002T Tii-74
1502Turbo-75
Volvo 264GL-75 export DE
Mercury Monteray -56
Har ett prob med ett köp av en 2002tii touring-74a.
Är det nån som vet om plåten med modell ser lika ut på just 74an, vet att usa modellen delar plåt med vanliga.
Så här står det
BMW 2002 Touring
Nr 3430312
Man vill ju köpa äkta var när det gäller dubbeli.
Mvh/Micke
Ny bmw 02 sida
tr
3.660
trucker
CS 3381
R75/7
325IT-06
330XI M-Sport
325 e30 -93
530DX-12 M-Sport
2002T Tii-74
1502Turbo-75
Så här ser det ut för USA men det måste ju finnas nåt liknande för Europa.
On this plate, it will identify the car as a 2002 TII for 1972-73 cars. 1974 cars share the same identification plate as the standard 2002, so the plate will read 2002/2002tii USA. The VIN number is the long number which is stamped into that plate. For 1972-1973 U.S. tii's, the VIN number will begin with 276, running from 2760001 (the first '72) to 2764522 (the last '73). 1974 tii's begin with 278, running from 2780001 to 2782929. This number should match the number stamped into the flange on the right front wheel housing itself, next to the fender, behind the hood lock bar, as well as the number stamped into the metal plate on top of the steering column. If the car still has its original engine block, the engine number on the block, above the starter mounting flange, will match the VIN.
Ny bmw 02 sida
