Allmänt om bil och trafik
646
Beräkningsprograrm on-line (länk)
ErikW
E28 520i - 85
E32 750iLA - 89
E92 325iA Coupé - 08
F11 530i Touring - 12
Hittade denna Länk med "Automotive Calculations", som innehåller följande interaktiva beräkningsmöjligheter:
Design Your Own Internal Combustion Engine
Ignition Circuit Simulation
Aerodynamic and Rolling HP Loss Calculation
Compression Ratio Calculation
Miles-Per-Gallon Estimation Calculation
Speedometer Gear Calibration
RPM & MPH Correlation
Best Differential Gear
Best Header
Battery Cold-Cranking Amp Estimation
Battery Cold-Cranking Amp Temperature Adjustment
Compression Ratio Influence
Engine Displacement Calculation
Driveshaft Velocity Calculation
Roadway Vehicle Dynamometer
ET and MPH Environmental Correction
Cylinder Head Flow Correction
Holley Carburetor Jet Program
Intake Runner Harmonic Pulse Prediction
Fuel Injector Sizing Program
Rough Engine Horsepower Estimation Program
RPM Range Program
Optimum Shifter Program
Erik
