oil pressure gauge - E30 M3 ?
sideways-sy
Hi, anyone ever fitted a gauge to the E30 ? how can I do it ?
any help would be greatly appreciated.
cheers Simon.
to fit a oil pressure gauge the easiest way is to use a y-adapter which screws into the position of the original oil pressure sensor...you simply screw out the original oil pressure sensor, screw in the y-adapter and then you have 2 connections where you can put both the original oil pressure sensor and your new sensor that gives the gauge a reading...any store that sells gauges can help you with everything that you need for the installation!
welcome to the forum!
MVH
Johan K
