Oljepumpskedja på en M3 E30?
Carpimp
Saleen S281sc
Hur "slak" skall oljepumpskedjan på en M3 E30 S14 -88 vara?
Vilka toleranser finns det?
MVH Morgan.
Oil pump drive chain, replace. S14
Remove splash shield from below front of engine.
Drain engine oil.
Remove the eighteen 10mm bolts from the lower oil pan.
Remove pan.
Remove timing chain.
Remove nut from oil pump shaft and remove gear.
Remove chain.
Installation:
Check gears for wear, replace if necessary.
Tighten chain by increasing or decreasing base shim size until chain has approximately 2mm of movement at the center point between the two gears, with light finger pressure.
Genuine BMW chains with green marks are longer than chains with red marks.
Part numbers:
Oil pump chain : 11 41 1 716 988
Oil pump gear : 11 41 1 273 689
Crank gear : 11 21 1 308 467
Shim, 0.1mm : 11 41 1 250 427
Shim, 0.3mm : 11 41 1 250 428
Torques:
Oil pump gear nut : 25 to 30 Nm (18 to 22 ft lbs.)
Carpimp
Saleen S281sc
Tackar och bockar för ett klockrent svar.
MVH Morgan.
