Hur demonteras dörrsidan fram på E39?
he
221
henrico
318i touring -02 (E46)
Skall byta dörrhandtag (insidan) och undrar om man måste demontera dörrsidan och i så fall hur görs det?
Sitter Airbag i dörren men skulle räcka att lyfta av pluspolen på batteriet enligt BMW. Stämmer det?
st
3.505
steaman
BMW 530i Xdrive -2017
Mercedes 350 GLE -2015
BMW X3 Xdrive30d -2011
Airbage sitter väl i stolpen? Den brukar vara märkt.
Så kär tar du bort dörrpanelen:
 Remove screw from inside forward vent flap (very important you do this first to prevent cracking the vent)
 Remove screw behind door handle (pop off cover plug first) T15 Torx
 Remove window switch (pry out with micro screwdriver, pull out and disconnect wire connectors)
 Remove lamp unit from bottom of door and disconnect wiring. Pry out with micro screwdriver from the front-most edge.
 The entire lower portion of the door panel is fastened with plastic push in clips around its perimeter. Use a long flat screwdriver (or similar) to pry the panel away from the door at each clip point. Start at the outside upper edge just above and below the opening for the lock (striker). Look for the next clip point and pry as close as you can to it. Be careful at the lower outside area - the clips are mounted on the rear of the plastic storage box (not on the panel). You have to push the screwdriver in all the way to the box and pry on it as opposed to prying on the edge of the panel - otherwise you can end up prying the panel off the storage box.
 With the lower panel clips all free, pull out slightly on the arm rest handle and then twist and slip the door handle unit back through the opening.
 Now pull the entire door panel slightly outward at the bottom and then lift upward - may take some wrestling to free it at the connectors by the window. Before removing the door panel reach in and disconnect the midrange speaker wiring connector.
Mvh, Steaman
540is
E39 M5 99' Bi-Kompressor
E39 540iAT 00' Kompressor
Finns beskrivning med bilder på Länk
